Power steering fluid
Where is the power steering fluid reservoir located ,just need 2 check the level ,thanks
Under battery, need to take battery out, airbox and battery tray out to get to it.
Also, need chf fluid, green stuff, to top up, suggest you get this before so you don't have to out car back together and undo it all again when you realise it needs topping up.
You'll need, 10mm spanner or socket for battery terminals, 13mm socket with extension for battery tray, and small torx bit and large adjustable pliers for airbox.
Cheers bud
