ordering spacers need advice..cheers
Ok folks got the car lowered 40mm on h+r springs but i want to order wheel spacers ive a 2011 fabia tsi 85bhp ...are these the right dimension 5 x 100 . 57.1 hubcentric maybe 15mm or 20mm i will need longer bolts to fit my 16" factory alloys anything else i need to consider .cheers. :think:
Prob need to consider if the rims are gonna hit the arches going round bumpy corners! Personally, I wouldn't go past 10mm, unless you are talking about the pair, not each. You may also need to change the locking wheel bolts as these may not be up to muster but I guess this is a small cost, after everything else you have done!
  • Sponsor
15mm will be bolt through so you'll need longer bolts where as 20mm will most likely be bolt on so you'll use your standard bolts.
Damian @ DPM Performance
thanks for the advice folks... :sun:  :sun:  :sun:
