Over boost problem
Hi all
Can anybody help as I am at my wits end.
My problem is with my Mark one Skoda Octavia Vrs 1.8t ( 180bhp).
When I put the throttle pedal to the floor turbo makes all the noises but no power,TC lamp comes on.Sounds like turbo is dumping the boost.
Fault code read is max boost pressure exceeded ,MAF sensor above threshold.
So far what I have done.
New MAF sensor
Belled out MAF wires to ECM all good,checked voltage 12v on blue,5v at red/purple
New N75 valve
New turbo actuator
New dump valve
New Y pipe and nearly all turbo pipes changed
Other pipes checked also for leaks
Re-set ECM to factory mode via 00000 coding
New spark plugs
New coil packs
Air filter replaced
Tired of throwing money at this fault,been told could be throttle body but again the cost.
Any ideas would be much appreciated,or if anybody could recommend a tune specialist in the Redditch are.
