Fabia Tdi maf removal
I'm trying to remove the maf sensor on my Fabia PD100 in order to check and clean it if neccessary.
Problem is, I can't even get the plug out! I can't see any latches etc, and I don't want to force it. Any advice welcome. Thanks.
Doesnt the plug just pull off - it's got two little clips that hold it in place, push those out of the way gently and you should be ok.
Perhaps someone has a pic for you :)
