help needed
hi how hard is it to remove and replace the rear quateron a felicia?
I've never tried it but I'd probably look for a replacement Felicia before I did even if I had professional bodyshop facilities, which I don't.
Why do you want to?
which side? the left hand one is an almighty ball ache to do, there's about a ton of that stretchy sealer to remove and about 100 spot welds to drill out, the rear quarters are double skinned and it's hard to seperate the inner and outer sections at the arch lip where the panels meet.. The right hand one is twice the amount of ball ache because of the fuel filler neck.
my advice would be if the arches are shot just get a body shop to put some repair panels in there, it's really not worth replacing the entire panel, the repair panels are about £25 each.
