Vacuum pipe size
Does anybody on here no the internal diametar off the vac pipes that come off the n75 valve pritty sure its 3mm but could somebody just verify it please
I bought 3 and 4mm
Ended up using the 4mm but both will fit :)
Is the 4 a tight fit? U use just the 4mm for all the vac lines from the box?
4mm wont go anywhere :)
If you want a really tight fit and are using silicone then 3mm will slide over too.
I have used 4mm mate
What pipe have u both used? Have u got a link?
