yeti rubber door strips
Please can the owner of a new Yeti tell me the length of the door mounted rubber strips that run horizontally half way down the side doors?
My dealer tells me that if I want to order , they will arrive grey, & will not look good sprayed black because they are dimpled....
This morning I spotted a 13 plate Yeti in Andover with just what I need, and guess what...? No sign of dimples whatsoever...AND  would look great on my wife's Fabia Monte Carlo.
Perhaps there is another source other than the Skoda dealer..?
Regards,
TDM
Horizontally? Do you mean vertically?
Or do you mean the self coloured horizontal side strips that are supposed to protect you from other peoples doors? if so, they are black(ish) or a very dark grey.
Edited by speedsport
If its the bump strips you are referring to the front are 935mm and the rear 590mm..The fronts are shaped at the front, the rears at the rear so these are the maximum dimension (give or take a mm or so - the old eyes aren't what they were!)
Yes, horizontal....
My thanks to Paul52!
Regards,
W11A
