Rear bumper fouling on tailgate
Hi All,
New to this forum but looks like a good resource.
I have an unusual problem with my Fabia estate. After leaving it in a airport car park for a week I noticed paint flaking along the bottom of the tailgate. My assumption is someone drove into the car, although there is no evidence of this.
On further inspection I've found that the tailgate is catching the top of the bumper everytime it is opened and closed. There is an evenly spread faint mark across the entire top section of the bumper.
As the paint has now started to flake off the first signs of rust have appeared so I am keen to fix this.
I am sure I could find a bumper removal guide somewhere but once I have the bumper off I am not sure how difficult a repair this may be. From what I have described does anyone have any idea what may have happened to cause this problem?
I'll look to post some photos in the next couple of days.
Welcome to the forum.
The reason seems to be obvious from your description.
The rear of the car collided with something or something collided with it.
Pushed it up.
Once the Bumper is removed, it may just be Deformed Mounting on the Plastic of the bumper,
lets hope so, if it was a low speed impact no damage should have been done to the Mounting on the cars metalwork.
I would be tempted not to remove the bumper yet.
Cheapest and best if not, incase you break the plastic while trying to straighten it.
If you do not fancy trying yourself, maybe ask at a body shop.
But since you are doing your own paint work you might give it a try.
Some careful use of applying weight to the top of the bumper might get it back in alignment.
If the bumper needs to come off, the Body Shop might just gently heat the mounting point and realign.
(EG Gently forcing the bumper down by standing on it.)
Sorry that this is not very technical but it does sometimes work.
Not jumping on it, but easing it down.
george
It's as George says, very likely someone has leaned on your bumper,probably with their 4x4 :devil: . All it takes is for some clown to mis judge and let your bumper take the weight of their vehicle. The composite material the bumper is made of will deform and spring back and if it's just done slowly but with full weight it might not even mark the paint but very likely bend the mounting straps, thus throwing the bumper out of line.
Personally it would be a trip to a good body shop for me, but then I wouldn't have the confidence to do it myself. Good luck. :thumbup:
Thanks both, really helpful advice there.
From what you have said it sounds like it could be a straightforward fix for a body shop. I might take that option!
Had this issue on the previous Yeti but it turned out to be tailgate door movement not bumper, as the bolts holding the hinges to the bodyshell had worked loose slightly.
TP
Dead right TP. Forgot to say that, do check the door fixings first!
DOH, sorry,
i was assuming that was a given.
Assumption is a bad thing.
I haven't even thought to check these....now you mention it seems like the 1st logical step. I'll check 1st thing this evening!
Ok so the bolts seem fine. I'm going to head down the body shop later this week so they can take a look at it.
Good luck, it will be interesting to see what they find. Hope it's minor as it sounds like. :thumbup:
