how do i adjust my digital tuning box?
right, i have been told you can adjust the draggon digital box, am i right? how though? it looks a sealed unit to me? help needed please? also if i adjust it and i get a bit to much smoke, would a green filter sort this or will i have to knock it back down? cheers? :thumbup:
what type of box is it? ...metal.... if so the one I had there were two screws in the end and the end cap pulled off then there was a line of small plugs these could be moved to give different levels of go.... mine had 16
no plastic.
the box I had was about 1" x 6" x 3" and made of metal so not sure about yours try e-mailing them at mr hoot website ...they normally get back to people the same day
will do cheers mate.
what is the website? mrhoot.com is not workin?
Still haven't got back to me (e-mailed on Monday morning) so I took my custom elsewhere! ;)
Chris
My dragon box had little round plastic caps over the screw heads. Just pop them off with a small screwdriver to get into the screws. Once inside, you'll find a row of 4 'jumpers' which you use to select the setting. IIRC, all 4 jumpers off is setting 16, but don't take it as gospel.
same as mine all 4 out was 16 but it was a bit too much :eek:
what you mean by jumpers?
two pins come up from the pcb and the jumper/connector just links the two together.....very crude switch on or off
mikey - i have the octygone's instuctions.... want me to fax or post u a copy?
no fax mate, but id apreciate a breef discription on how its done. in a pm please mate.
no prob - ill try and do it tonight - :)
pm your email address - ill try and pdf the instructions thru
