Octavia 1 Fuel temp sensor
Hi folks,
Got code up showing 'fuel temp sensor' fault............where can I obtain one in UK(think it's a G81)? Local Skoda dealer only supplies the pump(?). Dieselgeek in US show one in their list but says it's for US spec cars........probably the same!
What year?
What engine code?
They are available separately from the dealer and are about £20 retail (incl VAT).
I don't think they changed the part over the various versions so I would guess the part code is 028906040C
Thanks. Car is 1999 registered and engine is an AGR.
Have you got one from your local dealer previously?...........mine says it's not available separate from pump!
028906040C is the correct part number. Quote them the part code. You will also need frame gasket for the adjuster. The seal is not available as single item but it's included in the gasket set 038198051D.
Is the dealer will not supply them, you can get them direct from Bosch.
The fuel temp sensor from Bosch is 2 464 509 015
The gasket set from Bosch is 2 467 010 003
Many thanks!
