Anyone found a cure to this?
Right been getting angrier and angrier over this issue does anyone else hate after it rains and you open the boot and water just ****es in? Has anyone found a way to stop or reduce this happening?
run a thin line of black silicone sealent along the bottom of the screen to fill the little channel and voila all sorted.
Will give this a go
If you open it part way and give it a few up/down 'shakes', you won't get more than the odd drip in the boot.
Takes 1 second out your life, so I've never found it a real problem.
+1 on the part opening technique.
Havnt gotten as far as siliconing out the gap on mine yet...
everytime i think of doing it i realise ive the works van parked outside... :notme:
The MK2 does the same. Someone on there has fitted clear door edge protectors down either side of the tailgate glass and has cured this problem.
Sent from my iPhone 5 using Tapatalk.
There is only one cure....buy the estate version....problem solved  :rofl:
+1 for opening technique with also adding a bead of sealant.
Sent from my Samsung S3
