rear axle bushes and bumpstops
hi guys anyone no if there is an upgraded rear axle bush that is oem as dont really want to polybush the back axle also where is the best place to get rear bumpstops as i couldnt seem to find any at euro car parts have found some on ebay but am unsure if they are the best option or if u guys are running anything different from oem all help is much appreciated
My bump stops are from eBay, have been fine. If you want longevity you can get poly bump stops.
I'm sure people have used mk1 fabia vrs rear axle bushes as a upgrade as there solid a not voided like the octy ones are,hopefully someone could confirm this? :)
I don't understand why you wouldn't want to polybush. The rear axle polybushes being two piece are so much easier to fit than OEM press types, and they're not really noticably stiffer (not on the rear axle anyhow), simply a lot more likely to last.
Polyurethane bump stops may bit a bit harsher though.
has any one on hear used the fabia vrs bushes on there octavia
Yes, several of us have used the fabia vrs bushes on the rear beam of the octy.
I assume you mean:
hear = here
there = their
i assume you mean
beam = axle
as i meant exactly what i put but some of us are in a rush and could not give a f... for grammar or punctuation or did not ask for your opinion on either spelling or punctuation
Keep it civil please.
Personally I'm never in too much of a rush to use proper grammar, spelling and punctuation.
Anyway back on topic. I'm running Superpro rear beam bushes and they're not harsh at all, and really easy to install.
I wish you good luck on your quest for help.  However in the future asking valid questions might be helpful.
Edited by mbames
Rob - he wants axle bushes, not beam bushes....  :rofl:   Obvious he knows better than we do!! :giggle:
i am not going to bite as some ppl need to grow up but i would appreciate it if u didnt bother posting on any of my threads in future and leave them for the members that actually want to help on the forum which there are many sadly u always get one looking for a flaming session
I used the fabia vrs ones on the back of mine. They are still voided, so not to harsh, but they're stiffer than the standard ones.
Yep I have these, same as Seat LCR but cheaper
And here is the DIY guide I did from the Octavia techi section  if you want to have a go yourself.. :thumbup:
http://www.briskoda.net/forums/topic/215352-howto-changing-mk1-octy-rear-beam-bushes/
