Need inter cooler pipe!
If anyone could tell me where I could buy a silicone pipe I will explain as I can't get under to take a picture at the moment. It's the s shape pipe that goes from the bottom of the turbo too the intercooler I know you can buy the set for £135 but I only need that one and can't find it to buy it on its own
Or if anyone has one I have money waiting. It's a 1.8turbo vrs.
Thanks guys
But you running big tubby?? So will be diff or should be
Oh really? Nightmare do you know where I could start Clive? Would I have to get one made?
What setup are you running? I may be able to help if I have a bit more info dude!!
I have a few decent silicone hose parts that may be of use to you!
Samco 90deg bends and a black forge lower intercooler hose that may be of some use?
Take a pic it may be standard
Ok mate hang on ill try and get a picture and thanks mark ill get a pic on here and see if you have anything, defo isn't a 90degree it's an s shape
Posted Image
It's the one that goes up after the squashed metal pipe behind the driver side wheel
Posted Image
Yes standard !!!
IMO your better off changing the fmic setup ASAP !!!
Unfortunately I can't afford to mate else I would all the other pipes are blue silicone it's just that one and as you can see from the moisture it's leaking slightly so any ideas where to get a silicone one?
Will your black one fit this mate?
Wtf? Haha I looked everywhere for one on its own well I assume its the right one. Thank you mate if I don't hear back from mark I will buy that one but if mark has one cheaper I would be silly not too. Thanks for your help guys
If its the pipe with the metal coupling on it that goes from the metal top boost pipe down to the pancake pipe....then I do have one!
All cleaned up in a box under my stairs!
PM me your address and I'll send it down to you!
It's free,I don't need it anymore!
Just don't go faster than me at Combe!
