Mot parts
Does anybody know where I can get some front braided flexi hoses and an offside rear coil spring . Also failed on suspension ball joint and split seat belt and rear brake imbalance 38% not much but the brake imbalance will sting the most depending on how many times they take off and put on wheels n stuff
TPS, GSF, ECP?
Sent from my Nexus 4 using Tapatalk 4
Thought the VRS springs were dealer only
Ebay I saw at £33 otherwise it's gonna be £65 I think and dust covers at £20-83
For springs and ball joints, stick with genuine. Check TPS. Anything elsewhere is likely to be non-genuine, and getting the correct vRS spec suspension parts can be a real ballache. Almost every aftermarket spring that says suitable for vRS isn't, except for the decent lowering springs, that is.
FWIW, you really don't want to replace just the one 11 year old coil spring. That's just asking for trouble.
Cheers for the heads up
I should say specifically, those aftermarket springs that claim to be STANDARD equivalent vRS springs, usually are anything but, and most end up riding really high.
