Dashboard illumination
My dashboard doesn't light up any more. Any suggestions as to what this may be.
I did have the little side piece of the dash off where the fuses are and was trying to locate an anoying rattle behind there the other day. I can only think that i have buggered something up in the process. Any ideas on what to check etc would be very much appreciated. :o
Probably answered your own question there. Have you checked all the fuses?
Did you turn the headlights on?:rofl:
Check the connections on the back of the headlight switch and the dash dimmer which is next to it.
I am going to check the back of the dashboard dimmer switch as i fear i may have disturbed something. As to the fuses, can anyone tell me which fuse is the one for the dash illimination.
Rob
I am going to check the back of the dashboard dimmer switch as i fear i may have disturbed something. As to the fuses' date=' can anyone tell me which fuse is the one for the dash illimination.
Rob[/quote']
At the risk of sounding like a complete ****...
No, but have you tried the 'manual' ;)
