6 speed gearbox
My vrs aint got a 6 speed box i was thinking of putting 1 on as i do alot of motorway miles would the leon cupra 6 speed box fit? If not what one will
Yes it will but not a quick job
You need
Box
Shafts
Starter motor
Slave hydro line
Power steering line
Gearbox bracket
Shifter cables
Clutch and flywheel
And it's a bitch to fit
Stick to my 5 speed then
I thought somewhere I have been told that a 6 speed box off of a S3 wll work also....Others can post too.....
I've owned both 5 & 6 speed VAG 1.8t's both were around 3500 rpm @ 70 mph in top gear.
Hmm, so no real gain upgrading to 6 speed?  Why do they fit 6 speeds then, just a gimmick to sell the cars?
Edited by sammyhale30
Most 1.8ts with 6 speed, have K04 turbo, so extra ratios aid in spool up/reduce lag.
You need
Box
Shafts
Are you saying the inboard cv joints off the 5 speeds can't be used?
Just I've got to replace one soon,and mine has a 6 speed fitted.
(Sorry to barge in!)
Edited by swedey
Inboard cv are different buddy
Mine runs 2800rpm at 70mph!
Taller fears though of course......
It's good on fuel too,I can get 43mpg from it ;-)
