Fuel Filter size Octavia 2005 1.9 TDi
Hi,
I need to by a fuel filter for my Octavia and I am not sure what size I need. When I search EuroCarParts or CarParts4Less by the registration number I get filters with different dimensions, e.g:
1)
Diameter(mm): 83
Height [mm]: 143
Inner Diameter [mm]: 38
Outer Diameter [mm]: 83
2)
Diameter(mm): 78
Height [mm]: 135
Inner Diameter [mm]: 11,5
Outer Diameter [mm]: 78,5
3)
Diameter(mm): 84
Height [mm]: 118,5
Inner Diameter [mm]: 18,5
4)
Diameter(mm): 84
Height [mm]: 118,5
I tried to find the spec in the official manual but without the luck.
It seems to be a bit random as to what size is fitted to a car, so you may need to check what is in the car, or buy more than one and then take the unused ones back
Sent from my Nexus 4 using Tapatalk 4
on my 2006 vrs derv euro car parts listed completely the wrong filter so I had to get a different one so i'd sugest not risking it and make sure you get the right one
