rear window washer nozzles not working
can you help me .theres no water coming out of the nozzle ,ive put a pin in the holes still did not work,they stop working about a week ago.
front nozzles are working ok
thanks
Check the tubes are connect. In the boot area on the left side behind the liner i believer there is a join of tubes which is known to come off. Don't use the rear washer or all you will so is out water into places water shouldn't be in.
Also the little jet nozzle comes off sometimes with mine it gets bunged up and I soak it with some soapy water for a few hours.
Someone will be along to explain better about the tubing coming lose. Personally I've not had it but ready many threads about this issue
Mine stopped working & i removed the tailgate trim expecting the pipe to have come off & its was all ok,mine turned out to be a blocked up nozzle,i removed it & cleaned it & blew through it with my air line & its been fine since.
thanks i hav a look behind the liner, hav toke the nozzle off and cleaned it and put a pin down it ,blew it as well
If you use screenwash that isn't suitable for fan sprayers the rear blocks up pretty easily.
Tesco stuff is feckin awful for it.
If you've an estate check they pipe hasn't popped off inside the trim (water in wheel well) that seems to be pretty common
