aum agu auq differences in cai
Are the any differences from buying a aum agu cold air induction than one for my auq engine?
just i been offered one for nothing from an aum engined car.
Will fit fine
Must be 63mm which is 2.5 inch
If this car uses the oem maf should be OK
thanks for your help much appreciated
None at all from an air filter perspective. They all share the same airbox box and maf size. So you are good to go with any.
Sent from my Samsung S3
Not quite the same.
The AGU engine has an ignition module mounted and cooled on the airbox.If you remove that and left it in the  air uncooled it will overheat and fail
Not quite the same.
You miss my point buddy,  I said same size buddy, not what is on it or in it.
The question from the OP was can he fit a CAI from either of the engine code engines and that answer is yes. :rock: .
