Octavia 1 headlamp switch removal
Evenin all
As title suggests I'd like to remove my headlamp switch to connect the illumination wires for boost guage... Very uneducated in the realms of forums but tried a search but to no avail :(
Can anyone help??
You need to push in the knob then turn it clockwise slightly and then will just pull out :-)
You push the switch in and turn it (anticlockwise?) Then it will pull out.
Sent from my Nexus 4 using Tapatalk 4
It's clockwise to remove on my A4. :think:
Or, remove the side panel of the dash where the fuses are, there should be a small hole adjacent to the headlamp switch. Push a screwdriver into the hole against the side of the switch. Gently push into the switch/towards you. The whole switch should pop out
Mr Haynes say's:
'With the light switch in position O, press the switch centre inwards and turn it slightly to the right. Hold this position and pull the switch from the dash.'
Ta people
That's job number 1 for tommorow :)
