Blowing sound from cold VRS mk1 Octavia
I have a mk1 Octavia VRS with a blowing sound from cold, like an exhaust blow, once warm the noise go's, I presume this must be something to do with the auxiliary air valve, however I can't find where the leak is, the pipes from the pump seem ok, I was looking at the end of the smaller pipe, looks like a pierburg valve on the transmission end of the head, problem is the noise seems to travel and it is hard to locate,,,,
Any normal issues?
Thanks for reading
Its normal.
Thank you, I will look at this a bit later
Poor design really.
I've had the SAI housing rivets fail on 3 different VAG 1.8T's.
