What little options can be turned on/off Fabia VRS?
Im not sure whether this should be posted here or in VAG section but here we go.
I have read some other posts on here regarding the anti carjaking feature and an option to make the alarm beep when it is armed/disarmed, but what i want to know is are these the only options available, and is there any other things i can get the garage to do before we pick up the car.
You could add one-door unlock to that list, so that only the driver's door unlocks. You then press the remote unlock twice if you want the other doors to unlock.
All the possibles will probably be listed in the VAG-COM section.
Steve
Look in the vag-com section and FAQ's
Check out the VAG-COM guide in the Guides section that I put together when I made all the changes to mine :D
Chris
Sorry for hi-jacking but its sort of on topic ;)
I just found out that you can put the windows up and down with the ignition key in the driver's door lock (turn and hold it) But who uses the actual key to lock the doors?! Is it possible to use the lock/unlock button on the remote, say if I went to the dealers to program it or something :confused:
Thanks.
I just found out that you can put the windows up and down with the ignition key in the driver's door lock (turn and hold it) But who uses the actual key to lock the doors?! Is it possible to use the lock/unlock button on the remote' date=' say if I went to the dealers to program it or something :confused:
Thanks.[/quote']
No.
Fair enough! lol
