Turbo help please
Right guys I'm trying to fit up my turbo however I have a slight problem with the intake pipe, the old reducer doesn't fit onto the new turbo, so I tried using a silicone hose but it made the hard pipe sit about 100mm give or take lower so I can't connect it up too the back on the inlet. I was wondering if anyone has had to change this pipe and if so what too. Also do I need a breather or something like that?
Problem pipe; Posted Image
Also need a bolt to fit the oil feed line which goes in underneath the oil filter. Need a bolt with a hole through which looks like this;
Posted Image
Sent from my iPhone using Tapatalk - now Free
Most turbos will have this in the same place. Mine certainly retains the standard pipe as do many other.
What turbo have you got?
And you are fitting it to the right part of the turbo yeah?
What oil feed are you using? Have you made it yourself?
Luke
Luke
Ah okay. And a allard turbo t5b pr something not sure, bought it off dav-vrs.
Pretty sure I'm fitting it too the right part of the turbo? Lol. I hope so.
And not sure just a braided line with that on the end, came on the turbo, the standard pipe wouldn't fit anyway :/
Anyone else?
