New bluetooth kit works well with Bolero, doesnt appear in Maxidot
bought bluetooth kit (7P6035730K)
for my Skoda Yeti 2010 with its original Bolero double din radio.
just connected the fat connector on the back, and it worked like a magic.
BUT (why there is always a BUT), there is no control for the wheel nor indication on the Maxi Dot (white color) (which is supported with BT radio).
what should i do ?
is there any programming ?
Might need coding with the VCDS software. Someone will be along soon to confirm no doubt.
Older pre fl Octavias have this issue with that module. Its down to the way the cluster works using an older protocol. I dont know which protocol your Yeti uses but it might be the same issue I guess?
