Error code help
Hello,
Due to the engine management light coming on I have had a friendly member of the owners club run a diagnostic. The two error codes were 17704 and 16396.
The light has been reset and so far has not come back on. Can anyone help with what these codes mean? A have a mechanical breakdown warranty but need to know if failed parts are causing these codes.
The car itself seems to be driving as normal. :confused:
Cheers,
Darren
Hello' date='
Cheers,
Darren[/quote']
Twas not a problem Darren. A quick search of the Brisky archives reveals a fair number of results on 17704. Most appear to point towards temperature sensor, water pump or thermostat failure.
EDIT: Have found the other one, see below.
Hello' date='
Cheers,
Darren[/quote']
see http://www.briskoda.net/cms/BRISKODA_Technical_Guides/Diagnostic_%26_VAG-COM/Diagnostic_Code_List/
Twas not a problem Darren. A quick search of the Brisky archives reveals a fair number of results on 17704. Most appear to point towards temperature sensor' date=' water pump or thermostat failure.
Haven't found the other one yet.[/quote']
from ukmiv.net:
VAG-COM Version: Release 409.1-US
Control Module Part Number: 4B0 906 018 CG
Component and/or Version: 1.8L R4/5VT 0002
Software Coding: 11002
Work Shop Code: WSC 02325
Additional Info: WAUZZZ4BZ1N098790 AUZ7Z0Y1662173
1 Fault Found:
16396 - Bank 1: Camshaft A (Intake): Advance Setpoint not Reached (Over-Retarded)
P0012 - 35-10 - - - Intermittent
from ukmiv.net:
1 Fault Found:
According to AutoData, 16396 means:
Camshaft position (CMP) intake/left/front, bank 1 - timing over-retarded -> Valve timing, engine mechanical fault, CMP actuator
and 17704 means Engine Cooling System Malfunction -> ECT Sensor, Coolant Thermostat
