Problem with a Bury Bluetooth Handsfree Car Kit
Hi Guys
Hope You can help me with the following problem I have a Bury CC9060 Bluetooth Handsfree Car Kit Which was fitted in the car before I bought it. Up until yesterday it was working fine Today I get into the car turn on the ignition and nothing from the Bluetooth unit even the little touch screen is blank
Any help or advice you can give me would be much Appreciated Even if it's only to recommend a good car phone installer or auto electrician In the Cheshire area who could maybe diagnose and repair the problem.
Thanks in advance
Paul
Did you try using the kit, sometimes the screens pack in and have to be replaced but the kit should still function?
Did you try using the kit, sometimes the screens pack in and have to be replaced but the kit should still function?[/quote
]Hi yes I have tried to connect and use my phone even with the screen blank and my phone just keeps saying unable to find CC9060 please make sure its turned on and within range ????
where are you, i have  a 9100  maybe the fuse has gone or the connection they wired it in with has come adrift, if your near m6 junc. 19 wander over and we can have a look
Edited by pete8tch
I've got one of these fitted in my car. Same as you was in before I bought it.
Same problem once or twice with mine.
Just took it off the holder & put it back on & restarted the engine. This seemed to solve it. ? Connection problem.
Good luck!
Sent from my C5303 using Tapatalk
I've got one of these fitted in my car. Same as you was in before I bought it.Same problem once or twice with mine. Just took it off the holder & put it back on & restarted the engine. This seemed to solve it. ? Connection problem.Good luck!Sent from my C5303 using Tapatalk
Thanks for the tip Rob but unfortunately I've tried doing that already that many times that I'm sure I've started to develop repetitive strain syndrome lol
