Gearbox Gone! Help, any other gearboxes can put in?
Hi lads,
Gearbox in my Skoda VRS 1.8t is broken, it seems impossible to find a second hand gearbox from vrs, because there are not that much of them in my area. Gearbox from different octavia won't work as I know, or maybe Im wrong. because of different ratios. So if anyone can help me what to do? Recondition is very very expensive, so if anyone was dealing with vrs gearboxes, please help. Thank you
Thank you mate! So its 02j, will it be 100% fitment to original vRS gearbox? Will she work ok like the original one??
Edited by AlexDRD
100 % mate as my diff went and i had to change my box lol just make sure it is a 02J transmission box you will be fine
dont some 02j boxes have different ratios? i thought vrs gearboxes had longer ratios than the others
There's a different ratio set for just about every engine power output + gearbox combo
The ratio setup you'll find on a 150ps car will normally be slightly lower than the 180ps cars
Thank you mate! Big help, not its getting easier..
 And what will happen if I put in gearbox from 150ps to my 180 vRS?
It just means that you might not be able to travel at motorway speeds in 2nd gear anymore  :rofl: ....
Seriously though, You will just be doing different RPM for the equivalent speed.
so say in 5th at 70mph, a different gearbox could mean that your engine is doing 3200 RPM instead of 3000RPM etc. depends on the exact ratios.
The box will not be any weaker.
First and second gears are very long in our cars anyway so it will only make a difference if you'd miss that or are very fussy about fuel economy.
Edited by michael1
Now I see, thnks for explanation. Is there any other cars that have 02j 180hp gearbox on them? Just love a long go on 2nd gear  :rofl:  dont want to loos that with 150hp geabox. Is there anything?? :whew:
As far as I know, the other front wheel drive 180bhp+ cars had 6 speed boxes. Not sure about pre cupra leons?
Someone on here should know but there seem to be a good few vrs boxes around too.
Will try to find out :hi:
A few 02J ratio setups
iirc the vRS has an EHA box
"02J" 5 Speed  New Beetle, Golf/Jetta IV
Code 			1st 	2nd 	3rd 	4th 	5th 	R&P 	Notes
CZM 			3.300 	1.944 	1.308 	1.029 	0.837 	4.235 	 2.0L Beetle '98
DQY 			3.778 	2.118 	1.360 	0.971 	0.756 	3.389 	 TDI Beetle, Golf/Jetta IV
EGD 			3.300 	1.944 	1.308 	1.029 	0.837 	3.938 	 1.8T Beetle '99
DZQ,EBP,EGT,EKG 	3.778 	2.118 	1.360 	1.029 	0.837 	4.235 	 2.0L Beetle,Golf/Jetta IV
EKH,EMS,EZK,FBV 	3.778 	2.118 	1.360 	1.029 	0.837 	4.235 	 2.0L Golf/Jetta IV
EBJ,EGR 		3.778 	2.118 	1.360 	0.971 	0.756 	3.389 	 TDI Beetle, Golf/Jetta IV
EBQ,EMT 		3.300 	1.944 	1.308 	1.029 	0.837 	3.938 	 1.8T Beetle,Golf/Jetta IV
EGQ,FBW 		3.300 	1.944 	1.308 	1.029 	0.837 	3.938 	 2000-up 1.8T Golf/Jetta IV
DZC,EHC,EGF 		3.625 	2.071 	1.474 	1.038 	0.844 	3.389 	 VR6 Golf/Jetta IV
EWW,FBY,FCF 		3.625 	2.071 	1.474 	1.038 	0.844 	3.389 	 VR6 Golf/Jetta IV
EHA,EXE	(?)		3.300	1.944	1.350	1.030	0.844		 vRS, ED30 Golf GTi (?)
So much help mate, thank you!!!!  :hi:
get the EHA box which will be a 02j transmission and while the box is out look at ya clutch n flywheel
Seems hard to get EHA box, the only option is EHA box from Golf gti, which itself is rare  :think:
