problems with centrel locking ,petrol flap, dead locked osr door
Hi all I had a look around and found some of these codes which help but unsure if I have come to the right why of repairing it as the garage just want to replace the wiring looms and door motor switch's and locks in all the doors.
01331 drivers door module
0928 switch driver side implausible
0929 switch passage front
0930 switch left rear
0931 switch right rear
0944 heating mirror
0943 heating mirror
17608 boost pressure control valve mech problem (car has a hks valve fitted running .8psi on hks gauge )
problems that Im having with the vrs
mirrors not moving or heating both.
all doors not locking unlocking on door switch ,key or fob (key opens drivers and indicators lamps flash).
but boot is unlocking/locking on fob only indicators flash when you do this aswell.
dash door lamp is on when boot is unlocked goes out when you lock it with door switch or fob.
dash door lamp coming on with passager doors open and inside lamp coming on when open doors on
passager side and when unlock boot.
there is no working front door lamps or alarm lamp but inside lamp only works with passaged doors open and boot unlocked.
petrol flap motor is not opening
all power windows work are working on each switch and drivers switch's
not found any blown fuses
checked drivers window plug its all clean with all pins there
have found damaged to the door lock wiring plug i.e. pulled out of the housing
so if I replace this unit would it fix all the codes or do you think there a bigger problem some where?
also osr door is dead cant get it open outside handle inside hand don't open it but there some pull on the lock
lock pin is down and will not come up when you try to open from inside if you pull it hard it comes up but still dead locked
thanks for looking
thanks for any ideas or tips on the problems
