Interior light SMD's
Could someone please tell me what the correct length in mm for the interior light festoon bulbs, i've just spent half an hour reading old threads on here and the answers seem to range from 33mm to 42mm
Is the interior bulb also the same size as the number plate lights??
eBay links would be great if you have purchased a set and can vouch for them.
Take the old ones out and measure them ...simpies !!!!!!!!!!!!!!!!!!
I'm sure I found that the interior light bulbs are bigger than the number plate ones.
Tried putting the 43/44mm SMD LED bulb out of the interior light into the number plate light but it was too big.
I bought this one off eBay for my interior light, its not a canbus one so does blink sometimes but doesn't bother me.
http://www.ebay.co.uk/itm/300627955798
I've ordered x2 38mm ones for number plate and a 44mm for the interior
Hopefully they are correct
Already have some 501's for the "map lights"
Sent from my iPhone 5 using Tapatalk
I've ordered x2 38mm ones for number plate and a 44mm for the interiorHopefully they are correct Already have some 501's for the "map lights"Sent from my iPhone 5 using Tapatalk
I can confirm they are correct :)
That sounds right buddy.
I'll see how it goes with these bulbs first, mite try a set of these next:
  • 6 years later...
Old topic
But to save someone else time
Fabia vrs 1 blt has 30mm glovebox festoon bulb.
2xw5w t10 map lights
1 x center festoon 43mm length. Plenty of room width wise.
Boot light led 5w5 t10 x1 replacement will remain dimly lit when boot closed so stick with halogen.
Red doors lights are plenty bright for me so can't help. Risk breaking fixture. Seems to open from front to rear.
Led bulb used is Philips xtreme vision 4k
Edited by bmbmdmb
