Rear demister
Hi guys,
Just noticed my demister is not working. Press the button, light comes on, relay clicks in, and nothing.
Any ideas ?
Brookwood
Check fuse and connections would be a good place to start
Steve
Steve
Thanks Steve, fuse is okay and connections to the relay are sound.
It's a late 2011 saloon/twindoor. Any ideas how to check the connections on the window.
Lad
There seems to be several posts on this issue..
http://www.briskoda.net/forums/topic/231015-heated-rear-window-2/
I had mine at the garage and mentioned to them the potential solution mentioned in the other post.
All they did was check the fuse and the relay and ten said that they would need it for a 3-4 hour diagnostic (€400 odd) just to diagnose.
Parts and labour extra... What a con.
So I left it...
You not under warranty ?
If so take it back before it runs out...
Not under warrenty
Did you ever get yours fixed?
No.
I didn't have time to get it looked at and at €400 to diagnose I wasn't too keen to get them to check it.
The electrical guy in the garage hadn't a clue, I told him about what was reported here and he said he didn't know how the rear wind
ow heater worked.
I wasn't going to pay for his training.
In 4 hours youd rebuild a car not see whats wrong with the heated window...
Sorry for asking but your car is less that 2 years old. I got work done on year 3.... Id be going to the garage...
No.
ow heater worked.
I will be get it serviced soon but it's out of warranty since Feb. won't be giving anything like €400 to fix it, to be honest the air con keeps it clear quite well.
