VRS Max Boost Pressure
Hi,
I wondered if those that had VAG Com would advise the max boost pressure recorded in their fabia vrs with vnt17 turbo.
My car reaches a max of 1.59 Bar
Bryan D's 1.57 Bar
Jabba VRS 1.67 Bar
Also, I would be interested in the actual fuel injected values:
My car mk1 (std nozzles and turbo) 59.8 mk/st
My car mk2 (550 injectors, vnt17 turbo) 70 mg/st
Bryan D's Vrs 55.5 mg/st
Jabba VRS 70 mg/st
John
i presume you mean max constant boost and not spiked?
Revo - 1.5bar
What about boost pressures across the range?
What blocks do you use?
I have some data to share in csv format that can be viewed in excel.
Would others swap data?
Best wishes
John
Thought the standard car runs 1.6?
As a comparison, I think mine runs at 1.7bar continuously. vnt17 but with new bits inside :)
Would be interested in doing some logging though to see what vagcom reports :)
the PD130 runs about 1.4 bar stock
the PD160 runs 1.55bar stock
John - Are you running a new turbo or something? To get 1.59bar?
Been told mine might touch 1.8 bar as Allard tell me its using a lot of the gubbins from the 2.5 V6 turbo.
It's a new turbo - vnt17 bought from ebay. I think it can max at 1.7 bar?
I didn't realise you were buying allard hybrid turbo. I think it's the vnt17 casings with 2.5tdi v6 internals. I think it can run up to 2 bar !
Best wishes
John
Jason you should think about having an lsd with all of that power
Best wishes
John
Thats if he ever gets the thing running, bless him.
  • 5 weeks later...
Bryan D's 1.57 Bar
Jabba VRS 1.67 Bar
Also' date=' I would be interested in the actual fuel injected values:
Jabba VRS 70 mg/st
[/quote']
Just done some logs over dinner.
Stock mapping gives 1.35bar dropping off to 1bar at 4Krpm
Intresting to see it only took me 17sec to hit 90C :eek: Think I need a FMIC
:D
