Anyone seen it on t.v?
Hi all,
Anyone seen that advert on t.v for steel seal? Apparently it's a fix for head gaskets on there way out. Money back if it doesn't work apparently.
Has anyone used this? Think mines on its way out, obviously looking for a cheaper fix than replacing the gasket.
Yep, used them before, always worked.
Do a search, it's been mentiond on here loads if times.
Great, sorry about that. Got a bit excited when I saw it. Will so a search.
yeah you can get everything to fix you car in a can
if your oil seals leak you can put a can of **** in that makes the oil as thick as **** so it doesnt leak
if your rad/head gasket leaks you can put a can of **** in so that it bungs up the hole stopping the leak and other cores of the rad / heater matrix
and many many more ....
none of which actually cure the problem just bodge it up ....
