Indicator relays
Does the superb have indicator relays??? and where are they located if it does
Dropped the car off at the dealers for them to plug in and tell me what I need to know, mec only had basic diagnostic fault finder
No, no relays.  The indicators are driven by solid state devices, probably MOSFETs.  These are located in the voltage control unit, in the drivers side footwell just forward of the little storage cubby.  The wing mirror indicators are driven by the door control units in each front door.
The wiring colours are as follows:
Wiring colours:
Front Left: Black/white for supply, brown for earth
Front Right: Black/white for supply, brown for earch
Rear Left: Black/white for supply, brown for earth
Rear Right: Black/green for supply, brown for earth
Why 3 colours are the same and one is different I do not know.
The best place to tap off the signals are at the lights themselves, as the voltage control module is a very busy place with wires going everywhere.
If you're especially motivated and want to do it at the control module, here is how to get to it:
It was the voltage control unit J519, that went faulty, allegedly there is an update to this unit to rectify this problem can anyone confirm this
Edited by skippy41
Got the car back late Thursday, hit with a bill of £546 ouch, for some reason they checked the rest of the car, and found the sidelights dim, they are a bit, as they are meant to match the 500K hids, and the front wishbone bushes split???
Went to open the car it would not unlock with the bliper, found it was open so tried to lock it they had forgotten to code the key 5 mins later sorted
Edited by skippy41
Out of curiosity, did the invoice split the parts and labour charge?
Will do when I get the bill back, I put it down to grab a free coffee and choccy biscuits and forgot about it, lol
Right dealer sent me the invoice.
work requested investigate indicator inop on osf and nsr, customer has checked wiring and replaced bulbs
authorized 1 hours diagnostic
vehicle health check.
work completed, carried out diagnostic check traced faults to body control module J519
replaced and tested ok value £240
authorized 1 hour diagnostic and vehicle health check
labour  £240
rapid part delivery £5.00
total £456.39
vat £91.28
total £547.67
for customers attention wipers smearing
both front wishbone bushes split
Edited by skippy41
Thanks for that Skippy.  Seems like about 2 hours labor to swap and code which seems reasonable.
