How do I remove the front grille?
As the title says...
It's the lower section between fog lights which looks like it should come off easily enough but I can't find any obvious fittings.
I'm planning to fit some gauze/mesh behind the grille to protect the already peppered air con condenser and would prefer to have the part removed for better access.
Any knowledgeable input which doesn't involve wheels and bumper removal greatly appreciated.
Bump...
I managed to remove it.
I pulled both the smaller side grille segments out, simple click fit.
The main section required a large flat bladed screwdriver to lever clips at either side, top and bottom and strong fingers to prise double sided clips from the vertical vanes.
