Mk1 Fabia VRs Engine fan
hi all
just wondering if anyone can help , engine fan and a/c fan are not working i changed the rad ages ago and the fan wiring was ****e so i renewed that , but they do no look like they have worked for ages , it does not bother me too much cause i dont do much millage and never sit it traffic so it overheats
could it be the fan switch on the n/s below the battery box ???
ta martyn
Could be a few different bits, I had similar issue recently. The order I went through to check was first I hooked the fan up directly to the battery to test it's function, then bridged the fan switch to check that, then was going to test the fan controller box which i discovered was in bits! New one fitted and all is well again.
Sent from my HTC One X+ using Tapatalk
