headlamps steaming up
I have an 08 fabia mk2 in yellow
my headlamps of late have condensation in both lights
any ideas what the cause could be and has anyone had similar issues?
as a side track I have installed led lights in footwells, door handles, full hid kit in fiogs and headlights, led screen washers, drl's, anyone wants pics message me
thanks for your help on this
It's more than likely down to condensation due to temperature changes and the headlamps not being completely airtight.
You can use photobucket or a similar app to add the images on here
Made holes in your rubber boots to fit your hid wires through? Is it sealed?
What Otaylor38 said. Check all seal cups - if both headlights are having the same issues (which is suspicious) then something right after you installed the HIDs is probably the culprit.
