Dash Command
Mine did this a few times at first. Did you have to enter a password?
  • Replies 76
  • Views 7.2k
  • http://www.ebay.co.uk/itm/New-OBD2-ELM327-V1-5-Bluetooth-Car-Auto-Scan-Tool-UK-/151179946246?pt=UK_Diagnostic_Tools_Equipment&hash=item233306e906
  • Thanks for the offer James, but I just ordered one
  • I have this one Matt, slight trimming of the plastic dash pocket and it can be left plugged in all the time.   I also have a Pioneer head unit and its all showing on there.
No I wasn't prompted for a password Charlie.
Also those of you with fabias, what did you put down as vehicle make etc as skoda fabia isn't on there.
My scanner shows as CLKDevices.
Did you get the one fabooka linked?
I manually entered the car details for the fabia. Still not had a proper play yet. I started activating the pids but forgot to press start logging so i only had volts
Mine shows clk devices too. I just entered skoda fabia in manually. Had it linked to the t5 transporter too and cleared a couple of fault codes
Has anyone used REV?
Pooh it works now. It appears it wouldn't work until I had entered a vehicle.
A few pics.
The £27.99 one?
Yea
It's a bit expensive.
I have managed to get mine connected but I still see no values on there. Everything reads 0 or n/a :(
That's about as far as I've got. You need to go to your vehicle details and check for the pids and I think you have to activate them
As above.
If you using the logging option then you can go in and select what you want to log.
For the dashboards, as long as you have done the PID detect these should work straight away.
As above.
You mean the bit in vehicle where you "validate pids" ?
Finally got it working. Had to delete my vehicle and start again. Not sure what went wrong but it works :D
Awesome, I'll bear that in mind if mine doesn't start working :)
Why don't people post links to the one's they've purchased and have proved it to work?
Does this work in real time as in as your driving ? Or just when your parked and connected to wifi ?
Real time
That's good how does it stay connected without wifi ? Whilst driving
It connects via wifi and stays connected.
Had a run tonight to my brothers, it connected ok, so the revs and speedo was working ok, as were the other dials. It didn't bring up the power or torque though. I don't have anywhere to mount my iPad so it's a bit tricky monitoring intake temps etc
That's ace I'm going to get one I think
The check elm 327 obd2 ?
Will the normal size fit with the ability to stay connected all the time without any dash plastics issues ? As I can't find a mini in wifi .
