Rear calipers
I was wondering does a 02plate golf gti 20v tubs have the same rear calipers as my fabby vrs
Sent from my GT-I9505 using Tapatalk
I think it'll depend on the power of the engine
150bhp
I got a rear caliper off a gti from the breakers to get my car through a MOT. I think if it has a solid disk (232mm) they are the same. May be wrong, but mine was a straight swap.
difference piston size, will fit though
Would that work as a cheeky upgrade then if the have larger pistons but still attach to our carriers?
Sweet ive got
One simple way to check if they are the same is to get a part number by feeding both cars ID into ECP etc. First thing will be the "fist" width, next will be fitting detail, then slight issues like, does Golf have external return spring + does handbrake mechanism pull "up" or "down".
