Lock/Unlock switch does nothing - what have I switched off ?
The Lock/Unlock switch does nothing - what have I switched off ?
The switch at the front of the driver and front passenger door (With open/closed padlock) - when I stop all the doors are locked.
They can be opened from inside but, not from the outside.
What setting have I messed up ?
Chris
Sounds like you've enabled anti hijack.
Do you hear them lock above 10mph?
Yes - but, I expected to be able to press the switch to the unlock position and all the doors would unlock ?
Chris
Which it will when stationary.
The switch doesn't respond :wonder:
Dead switch maybe?  Does it unlock if you double crank the handle?
When I open either front door using the handle - the other one is unlocked BUT, not the rear doors or hatch/tailgate
Edited by L200man
Check all doors & boot are fully closed.
Might be worth getting a vcds scan done
I have figured this out - you need to press and hold the switch for a count of 3 and then it unlocks/locks
Chris
