Poorboys
You will have to post how you get on with it, i too have a black VRS and am considering buying some of this myself.
I will do Matt has very good reviews
Sent from my GT-I9305 using Tapatalk
I've used Black Hole on my black magic Octavia VRs for about a year (it replaced Autoglym SRP) and it's fantastic! It is much less dusty than the SRP and, in my opinion, is slightly more glossy. It's easy enough to use as long as you use it quite sparingly and it will fill some of the shallower marks in your paintwork. I top it with Poorboys EXP and then put some Victoria Wax Concours and get great results (although, for longer lasting protection I use collinite 915).
I recommend it highly.
Thanks big man. I have got SRP to go underneath the black hole then the EXP on top
You won't see any benefit of using SRP before black hole! - either/or :)
That right .....unless youre using the slight cut of the AGSRP to clean the paintwork prior to the glaze
Both products have fillers
I use black hole on the cosworth and other various poorboys products and think they are fairly decent:)
Poorboys Black Hole Glaze is not a last stage product (LSP) ....that's why it doesn't last long
Therefore it should always be topped with wax or sealer
You need to seal in the glaze
