Did some coding
Did some coding today using a local independent's VCDS got 2 of the 4 changes I wanted to do OK, am now hooked on trying to get everything just the way I want, what are peoples opinions, should I get a copy of VCDS to do this myself or do you play a bit and then it stays in the cupboard most of the time?
John
Mine stays out the cupboard.  It gets used by me for more than just faults and coding. :thumbup:
Once the. car is coded the way you want it it's then only used for fault code reading and coding other peoples cars.
OK, bit the bullet and got a copy (think I want to play a bit) so if the powers that be want to add me into the list of people that have it feel free :happy:
May be worth noting though that although I work in IT I will have to learn how to make this thing work.
Though if you are happy to be a test person and want something coded then we can learn together :rock:
John
