Seat bases and backs.
Is there any physical or mechanical difference between the normal seat frames and those of a vRS/ Sport. Any reason why I can't use my frames and swap the bases and back foam parts over for some vRS ones and add the covers?
I know there's a few seat gurus out there :p Thanks in advance,
Lee.
 The metal bits? nope none at all
my recaros started life as set of grey and beige out of a classic
and the Octavia half leathers started life as the same design in grey on grey
and both those resulted in exactly the same movement as the standard VRS seats
forward & back from the level at the front, height adjust on the side lever for the driver only
Dependent on your reasons though and assuming it's not a condition thing you just swap the entire back rest rather than having to move the foam and covers...
Top man, Cliff. Just the answer I was hoping for :D Right, next project can hopefully commence unless I'm beaten to things :bandit:
