Skoda Octavia Classic 2007 - Radio not working
Wondering if anyone can assist . My Radio and rear demister have stopped working following the usual rear washer jets issue water leaking into drivers side over the relay panel.
Anything specific  I should be checking - checked fuse behind radio.
Not sure if this has a relay at the moment I am being told no power going to radio or demister.
I am not sure which relays are for what - unless anyone can advise
Thanks all.
Have you checked the fuses to the right of the steering wheel?
Open driver's door and remove panel at end of dash.
Thanks I will have a look there and check the fuses again.
