Dsg7 gearbox
Hi
I have the new skoda octavia iii
It started in about 5500 km
There are strange noises that occur mostly when driving slowly. The transition from 3 gear to 2 is not smooth - there is a knock - not like it was before-a smooth transition.
Noise like "crack".
In gear 3 suddenly Rpm increased to 6000- feeling the car was in N.
Began noises of an electric noises-
Zzzzz
It starts it every few seconds and repeate.
serious problems after a long driving.
Sometimes when I want to accelerate example- from six gear to four
Feel a hit.
The main problem is in gear 3to2 there is a knock.
When I use the brakes sometimes the hit does not .
When I let the car slow itself the knock from 3 to 2
is strong.
What do you think it is?
Sounds like clutch pack or mechatronics.
Either way it's under warranty!
Phil
Noise like "crack".
Zzzzz
Feel a hit.
is strong.
Hi, sorry to hear about your problems! When you know more or get it sorted, please fill out the DSG Survey I run at
http://www.dsg-survey.com/
Good luck with your problems!
Hi
Noise like "crack".
Zzzzz
Feel a hit.
is strong.
Done a few of these on A3 and A1's it's normally the clutch packs need replacing and re shimming audi have released a technical bulletin about these
Hope this helps
Is it normal to feel like it's slipping when pulling away?
I get it doing it when you have the brake pressed as your stopping it moving
It is normal on the 6 speed but not the 7 speed.
Phil
Thanks Phil. Will get the garage to check when it goes for service.
On a related note, I'm yet to hear anything about the dsg recall to change the oil.
