Buttons below the climate control ?
Hi all
Looking at used 170 Elegance models online, and am trying to work out what options they may have fitted.
Sometimes non-Skoda dealers don't know what options are fitted and don't mention them in adverts, so am trying to see what I can work out from (often distant and/or blurry) photos.
Can anyone tell me what the 5 possible buttons are, from left to right, at the bottom of the dash below the climate control ?
Seems most 170 Elegances have two buttons as standard, I guess the central one is the offroad button, but not sure what the others are.
Thanks!
On mine - blank, TPS reset, Off Road, ESP off, blank (from memory!)
Thanks.
Wonder if the ESP button is actually on the right ?
Seems standard spec is: blank, blank, offroad, blank, something (ESP?)
L-->R
PA Activate
Parking sensors on/off
Off-road button
Tyre pressure monitoring
ESP on/off (I'm guessing ESP - turns off the anti-skid etc device judging from the graphic on the button)
L-->R
PA Activate
Off-road button
Great, thanks for that :)
Still undecided on your Yeti replacement ?
Prodata has it spot on, that what I have and in that order
I remembered seeing you had a full set. Show off :)
I think you need someone with VCDS Johann - I tried the ejector seat and it didn't work  :bandit:  :rofl:
Lee...  you need to open the sunroof BEFORE it will work.  Doh.  I had it coded that way very specifically.  :giggle:
