Abs and traction flickering on and off, power steering lifht
Hi started the car to day fabia vrs, Abs and traction light was flickering randomly, power steering light is on, also airbag light, the battary has been of the car and has stood for around 2 months, tryed to read with autocom diagnostic, comes back with,
18061 fault codes in abs controller- intermittent
18956 can bus performance problem- intermittent
I have tried to acsess the abs module through the diagnostic but it couldn't connect, but that may be due to software. Has anyone got any ideas what it could be.
Make the sure the battery is Fully charged! A low battery caused me to have these warning lights on dash! Charged it up and then had no lights.
Had a look to day. the dfm wires had come off fixed that. The battary is fully charged.
The power steering light is on, abs traction, battary light flickering. Checked most earths, cleaned an refitted.
Problem still there has anyone got any ideas what it could be .
take it for a drive m8 should all go out
Think I've found the problem, take the car side loom of the power steering pump the dash lights go normal, plug the pump back in and it goes on a mad 1 playing about with the plugs on the pump you can get the dash like a disco.
Going to get a second hand pump does it need coding, Also mine doesn't have the part number on can I use any power steering pump such as
http://www.ebay.co.uk/itm/331103080903?redirect=mobile
I know nothing technical at all. Nothing! But I assume you checked the 40a fuse on the battery in the engine bay? Read that being busted does some weird stuff sometimes? Did on mine.
