Coilpack question
I've search for a few days but I can't find an answer to my specific question.I fitted a new dv and went for a quick run,much better as I expected as my old dv was torn.Two mins later and a coilpack dies in my eyes due to the better performance.Now my question is that after a few weeks the performance and more so the torque has gone again and gives fairly lumpy power delivery.I plugged in vcds and no faults showed but when I scanned for misfires it showed cylinder. 2 and 3 were missing ( couldn't feel it ) .Can a coil be bad without giving a permanent miss? Maybe limiting spark /power to preserve the coil via the ecu ?
TFSI or TSI?
Sorry its a tfsi
Yes, replace all four.
Mine had a bad coil which would only miss when pulling hard through a gear from low revs. All other times it was fine, then it just failed completely but that was after about 3 months.
Ok cheers,along with everything else that's broken ill go order some more coils :(
