Changing fl octavia II bumper for fl vrs bumper
Hi guys has anybody swapped their fl front bumper for the fl octavia Vrs bumper and got their drls to work? If so what parts are needed? skodateile sell the bumper,grills, fogs and drl in a package and seems like a good deal.
anybody?
Yep I've done it! Works fine, will light up at 100% when ignition on. Only thing I haven't figured out and probably will not be able to is:
- No dimming.
- DRLs switch off when headlights turn on.
I'm sure it has to do with my VCDS light settings but I'm quite happy with the current set up.
You'll need to order the 3 wire plugs and 2 resistors. Your existing 2 wire plug from your halogen will plug into 2 of the 3 wires, the dimming wire will be omitted.
The resistors will remove dash error.
I'll hunt down the info and post for you...
Sent from my GT-N7100 using Tapatalk
Hi noo63n
just the man to let me know what parts I need then :happy:
popped into my local dealer and have inquired about whats needed but they said that parts are non refundable so don't want to buy anything i don't need too and also they mentioned that they may not be able to get it to work??
i am presuming all i need are the bumper, fog lights, drls and grills and also a bracket which holds the fogs and drls No 6 in the pic. the dealer also said that i would need a bumper bracket. no 5 in the pic.
Also this connector you are talking about, is that easy to get hold off? is it a genuine part?
