Brake Fluid Change
I will be giving the brakes a complete overhaul this weekend, replacing the rubber flexi's for Braided items and therefore giving the entire brake system a flush out and fitting new 5.1 fluid, my question however is how much fluid should I purchase?Will 1litre be enough for the job, or should I buy more?
I'm not sure on that myself. You could buy two then return one unopened?
I used just under a litre replacing the fluid: That's replacing all fluid from the clutch line, all brake lines and reservoir. I used a pressure bleeder which made things easier.
I only had to change it due to discoloured fluid and bits of perished rubber in the fluid.
The pressure bleeders, what, where, how, etc? I need an easier way to do the brakes.
Search for Gunson Eazibleed (possibly spelt incorrectly!) I have one of these are is sooo much easier than a manual bleed.
If you want to borrow one, I'm only in Colchester.  :rofl:
