hatchback liner removal
folks,
I need to get access to the rear wiper motor cause it's got that irritating intermittent works/doesn't work fault but I don't know how to remove the internal plastic cover. I know there's a screw at the pull handle but not sure where to go from there.....any ideas?
If my memory is right its just clips that hold it on after the screw is removed. It pulls down towards the rear bumper. The taking off bit is quite easy , stripping down the motor mechanism and rebuilding is easy, its the putting back on the plastic cover  thats the tricky bit.!
Edited by erindad
ah ok, so it kinda slides out rather than pulls off? The rear wiper is doing my head in, sometimes it works, sometimes it doesn't! aargh
